cquint
Jul 14, 2023Aspirant
WAX610 Slow
I have a WAX610 AP connected to GS108 Switch Connected to Netgate pfsense firewall. The wireless is extremly slow compared to the previous consumer Asus Router I was using. I have a 500mb connection ...
cquint
It is on 40Mhz, I have tried to used 80Mhz. It didnt seem to have a significant difference.
- schumakuJul 15, 2023Guru - Experienced User
The WAX610 is a AX1800 device, with AX1200 2x2 on 5 GHz, and AX600 2x2 on 2.4 GHz, permitting the full 80 MHz are available, and no competitive concurrent bandwidth usage on-air.
Consult duckware 's great composition of WiFi insights on https://www.duckware.com/ FMI.
