it-ledmax
Oct 09, 2024Aspirant
WAX610 upgrade to 10.8.8.6 firmware version issues
Hi, I am having issues with the new firmware (10.8.8.6) also. I have 15 AP's that are Insight managed (same firmware) - that have absolutely no problem. We also have another 6 that are not In...
BrianL
Oct 09, 2024NETGEAR Moderator
Hi it-ledmax,
Are these 6 APs on the same network? VLAN? powered via PA or POE/POE+? can you also share the settings on each? It is unlikely that all will have the same behavior after the FW update unless something changed in the network. Have they been rebooted after the update?
You can backup each configuration of the said APs so you won't have to reapply the settings one by one.
Kind regards,
BrianL
it-ledmax
Hi,
They are on the same VLAN, they are connected to a Radius Server, powered via a PA.
And Yes, they reboot by themselves a couple of times per day.
Thing is that before this firmware they were on for months - can't really explain it.
I will downgrade to V10.8.7.1 - and let you know how things work.
Somehow forgot about the config back-up.
Thank you,
LucianV
- BrianLOct 09, 2024NETGEAR Moderator
Hi it-ledmax,
You can share the logs of each AP of one of them so I can take a look at why it reboots. If you will proceed with downgrading the FW, let me know what happens.
Kind regards,
BrianL
- it-ledmaxOct 14, 2024Aspirant
Hi,
Rolled back previous firmware version - only on one AP and now it is stable for 3 days.On the one that was acting the weirdest - remaining 5 are on the new firmware but seem ok for now.
Weird thing with the new firmware.Thanks for any other suggestions.
Kind regards,
Lucian.
