it-ledmax
Oct 09, 2024Aspirant
WAX610 upgrade to 10.8.8.6 firmware version issues
Hi, I am having issues with the new firmware (10.8.8.6) also. I have 15 AP's that are Insight managed (same firmware) - that have absolutely no problem. We also have another 6 that are not In...
BrianL
Oct 14, 2024NETGEAR Moderator
Hi it-ledmax,
If the problem continues, I suggest you contact support. Prepare the logs for each affected AP and enable SDM (reverse SSH) by following the steps below.
1. Login to https://<AP_IP_address>/advanced_debugging.html
2. Enable Reverse SSH
3. Save and provide the 5 digit debug code to support.
Kind regards,
BrianL
