markfMK
Dec 27, 2020Guide
WAX610 WiFi Speeds
Hi I’ve had my WAX connected up for the last couple of days with various results. I’ve setup a dedicated 5ghz and separate 2.4ghz networks. I’ve got FTTP BT 900mb broadband coming into the hous...
LOTRouter
Jul 19, 2022Aspirant
I regularly get 720Mbps on my iPhone 12 when I’m standing under my WAX610.
The two things I have seen adversely affect the WAX610 are:
- Usine a POE switch or brick instead of a POE+ switch or brick. It will still power up and work, but it slows way down on the lower powered POE.
- Not hanging the WAX 610 on the wall or ceiling. Simply placing it face up on a desktop provides horrid coverage.
schumaku
Jul 20, 2022Guru - Experienced User
The WAX610, WAX610Y | Data Sheet does clearly states the mandatory requirement for 802.3at (that is PoE+)..
The radio pattern does not show reasonable anomalies. Differences experienced are caused by the desktop surface material, the mechanical design, ...
