Bobjosullivan's avatar
Mar 10, 2021
WAX610PA Restoring a working config
I'm in the process of setting up a remote location with 10 Netgear WAX610PA-100NAS points.  I have created one working configurion files and created the back up file and exported for use on the remaing (9) A/P.  In the past, this approach has worked and it has allows me config multiple A/P's in no time with this model this approach doesn't seem to work.  I conduct the restore, but none of the setting are carried over to the restored unit.  Is there a extra step, I'm missing?
1 Reply
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi Bobjosullivan
    It should work. If you dont mind Could you please send me your config backup files via PM?
    Thanks,
    Raghu
ProSupport for Business
