jimmykimmel
Mar 12, 2023Aspirant
WAX620 AP Not Connecting to WiFi
Hello! I can’t connect chamberlain myQ garage door opener via wax620 AP. All other devices I have are working and all bands are enabled. If I substitute the AP for a router, it connects fine. I need t...
- Mar 20, 2023All they did was power cycle both the AP and the chamberlain device (which I did as well), and then it started working instantly. Not sure at all what was the difference between me doing it and them telling me.
BasuKhodanapur
Mar 15, 2023Apprentice
Hello jimmykimmel
Any updates on the case, issue persist please help to provide above mentioned details.
Thanks,
Basu
jimmykimmel
Mar 16, 2023Aspirant
Hello Basu sar,
The issue is not persisting anymore. Sorry for the late update. I had contacted chamberlain as well before, and they gave me a remedy.
- areef-mullaMar 16, 2023NETGEAR Employee Retired
Hello jimmykimmel
Greetings! Happy to know that the issue is resolved. Would you mind sharing what change was needed on Chamberlain device to get this working?
Curious to know if any default config which needs to be changed.
- jimmykimmelMar 20, 2023AspirantAll they did was power cycle both the AP and the chamberlain device (which I did as well), and then it started working instantly. Not sure at all what was the difference between me doing it and them telling me.
