sirpreis
May 16, 2022Initiate
WAX620, Connection speed?
Hi, I am trying to set up a WAX620 access point. Currently I have had some 6 year old Linksys LAPAC1200 APs, which seem to not work as reliably as they used to. When connecting with my devic...
sirpreis
Ok, I guess the connection speed was probably due to me being stupid. I changed the channel bandwith setting to 20/40/80 MHz and then my devices get the 866 Mbps 🙂 Hopefully I get those setting resets after reboot and firmware update issues sorted as well.
Murillo014
May 17, 2022Aspirant
The Netgear WAX620 features a powerful internal antenna that can transfer up to 2400 Mb/s over 5.0 GHz and 1200 Mb/s at 2.4 GHz frequency.
