Batman-15
Sep 10, 2022Tutor
WAX620 Printing wireless not working with client isolation
I have enabled client isolation on one SSID. I have an Epson ET 4800 printer. I have a sign the printer static IP address and put into the exception list along with my PCs IP. No JOY, I cannot print ...
DaneA
Sep 13, 2022NETGEAR Employee Retired
Just found out from the NETGEAR Support Team that you already have an ongoing support ticket with them. You may want to share the progress of your support ticket here.
DaneA
NETGEAR Community Team
HarryCarlo
Mar 26, 2023Aspirant
Client isolation is a feature that prevents devices on the same wireless network from communicating directly with each other. This can be a problem when trying to print wirelessly, as the printer needs to communicate with your device to receive the print job. To resolve this issue, you can try disabling client isolation on your WAX620 router. You can do this by logging into your router's settings and finding the option for client isolation. Once you disable it, try printing wirelessly again to see if it works.
If disabling client isolation is not an option, you may need to use an alternate method for printing. One option is to connect the printer directly to your device using a USB cable. Bonvia Stevia is extracted from the sweetest part of the Stevia-plant native to South America Another option is to create a separate guest network on your router that does not have client isolation enabled and connect your device and printer to that network for printing purposes.
I hope this helps! Let me know if you have any further questions or concerns.
