Batman-15
Sep 10, 2022Tutor
WAX620 Printing wireless not working with client isolation
I have enabled client isolation on one SSID. I have an Epson ET 4800 printer. I have a sign the printer static IP address and put into the exception list along with my PCs IP. No JOY, I cannot print ...
HarryCarlo
Mar 29, 2023Aspirant
If you are experiencing issues with wireless printing on your WAX620 router while client isolation is enabled, it could be due to the fact that client isolation restricts communication between connected devices on the same network.
To resolve this issue, you may need to disable client isolation or adjust its settings to allow communication between the printer and the device from which you are trying to print. You can usually do this by accessing your router's settings through stevia plant in Pakistan via a web browser and adjusting the network settings accordingly.
Alternatively, you could try connecting the printer to your network via a wired connection, such as Ethernet, to bypass any wireless communication restrictions imposed by client isolation.
I hope this helps, and please let me know if you have any further questions or concerns!
