BobSimmons
Oct 20, 2022Aspirant
Wax620 very slow
Recently I deployed two WAX620 wireless access point for a client, in his newly constructed house. The house has 1 Gb/sec synchronous Internet service from AT&T. All Cat 6 cable is new and has been c...
BobSimmons
Oct 21, 2022Aspirant
Are you testing over the 2.4ghz or the 5gh? Both.
How far from the access point are you? 20 feet
What device are you testing on? PC, iPhone and Samsung Android phone
do you have any bandwidth control setup at all? I assumer you mean rate limiting ... no.
Is it both access points with the lower speed? Yes.
Oct 21, 2022Guru - Experienced User
When more than AP is having the same issue, it makes me suspiscous of the device testing with and the router they're connected to.
What model devices are you testing on. You listed pretty generic devices. Its important to know what wireless cards are in them.
And when you say you tested on both 2.4ghz and 5ghz, what speeds did you get for each?
I don't have any of the business class equipment (other than a SRK30) so i'm not sure how to check the wireless settings/configuration on them. schumaku would be a lot more knowledgeable about those than I would.
