jasondunn
Oct 24, 2022Apprentice
WAX620PA APs: Where's the speed?
I recently set up two WAX620PA access points in my home replacing a pair of ASUS ZenFi ET8 mesh routers that were fast but extremely unreliable. The WAX620PA APs are connected to power, not using PoE...
- Oct 24, 2022
Looks like I'll fix my own problem and put the answer here so others may benefit. Steps to fix:
1. Go into the app
2. Then Radio and Channels
3. For the 2.4 Ghz radio, change Channel Width to Dynamic 20/40MHz
4. For the 5Ghz radio, change Channel Width to Dynamic 20/40/80MHz
5. It may not save the first time you make this change, so save the settings then pop back into the settings screen in a few minutes
6. Repeat until both entries show they are set to Dynamic
The results?
The Pixel 7 now gets 785mbps down and 40.7mbps up
The iPad 11 now gets 435mbps down and 31mbps up
The MacBook Pro 14 now gets 786mbps down and 33mbps up
The real question is why isn't this the default configuration for these APs? Why not ship for max speed then let admins tweak as needed if the high performance settings aren't what they want?
jasondunn
1. Go into the app
The results?
- Jul 18, 2020Retired_Member
