aguden_guden_co
Sep 03, 2021Luminary
WAX630 - Installed but set up 2 wifi networks in errot
I added 2 WAX6302 and when I did I created 2 separate WiFi networks in error. I wanted them to both be in the same wifu network. How can I change that? New to this concept of WiFi networks and I a...
- Sep 04, 2021
Alternate to Insight (not available in all countries, small cost, ...) it's possible to manage the WAX individually. On Management > Configuration > Wireless > Basic you can select the SSID you intend to change, then change the name, security PSK, ... to the same value like the other access point.
Sep 03, 2021Guru - Experienced User
If you start at page 44 of the manual it goes over setting up an Insight managed mesh network.
They should come with 1 year of insight included.
schumaku
Sep 04, 2021Guru - Experienced User
