Dankoe
Dec 20, 2022Aspirant
Add WAX630 to SXK80/SXS80 network?
Hi, I have a location with only PoE so I can't add a SXS80 AP. Can I use a WAX630 instead or is this incompatible with the Orbi Pro mesh network?
Thanks.
Daniel
Is there any technical solution that supports PoE with Orbi Pro devices?
I'm afraid there is none. All of the Orbi Pro devices uses a power adapter to power it on.
DaneA
NETGEAR Community Team
