Dankoe
Dec 20, 2022Aspirant
Add WAX630 to SXK80/SXS80 network?
Hi, I have a location with only PoE so I can't add a SXS80 AP. Can I use a WAX630 instead or is this incompatible with the Orbi Pro mesh network? Thanks. Daniel
DaneA
Dec 20, 2022NETGEAR Employee Retired
Welcome to the community! đ
The WAX630 is not compatible to sync with the SXK80 or to any Orbi Pro device.
DaneA
NETGEAR Community Team
- DankoeDec 20, 2022Aspirant
Ok thats unfortunate. Is there any technical solution that supports PoE with Orbi Pro devices?
