Dankoe
Dec 20, 2022Aspirant
Add WAX630 to SXK80/SXS80 network?
Hi, I have a location with only PoE so I can't add a SXS80 AP. Can I use a WAX630 instead or is this incompatible with the Orbi Pro mesh network? Thanks. Daniel
DaneA
Dec 20, 2022NETGEAR Employee Retired
Welcome to the community! 🙂
The WAX630 is not compatible to sync with the SXK80 or to any Orbi Pro device.
DaneA
NETGEAR Community Team
Dankoe
Ok thats unfortunate. Is there any technical solution that supports PoE with Orbi Pro devices?
