matt0009
May 24, 2024Follower
WAX630 Guest separate from another SSID
Hello,
I added SSID (2nd) as "Guest".
Can we use this guest SSID separate with 1st SSID?
Is this possible for WAX630 model?
thank you for in advance
MTT.
Yes, of course.
- Either configure the Guest SSID into a dedicated VLAN (something your switch and router must support), or
- configure the Guest SSID mapped as NATed instead of bridged, so it runs on a private IP subnet within a single WAX6xx.
Adding to schumaku , You can enable client isolation in the Guest SSID, so that the clients connecting to Guest, will not have communication among them and other SSID as well.
