Bobiskey
Jul 07, 2022Aspirant
WAX630 Guest WiFI setup
So, first off, I am coming at this from the Meraki and Sophos back ground. So bear with me 🙂 In either Sophos or Meraki you could setup guest wifi on a separate ip range that would then be NATed...
- Jul 07, 2022
Welcome to the community! 🙂
Kindly check this video tutorial below on How to Create a Guest Network via NETGEAR Insight:
DaneA
NETGEAR Community Team
schumaku
Jul 08, 2022Guru - Experienced User
Netgear does offer industry standard VLAN config for the Smart Switches, and for the SSIDs to VLAN matching. This does combine well with any industry standard security appliance supporting multiple local networks, ideally with VLAN support, and subnets. Management can be done on cloud managed APs and switches by each single device Web UI, and by Netgear Insight.
