Bobiskey
Jul 07, 2022Aspirant
WAX630 Guest WiFI setup
So, first off, I am coming at this from the Meraki and Sophos back ground. So bear with me 🙂 In either Sophos or Meraki you could setup guest wifi on a separate ip range that would then be NATed...
- Jul 07, 2022
Welcome to the community! 🙂
Kindly check this video tutorial below on How to Create a Guest Network via NETGEAR Insight:
DaneA
NETGEAR Community Team
DaneA
Jul 07, 2022NETGEAR Employee Retired
DaneA
Bobiskey
Jul 12, 2022Aspirant
Thanks DaneA
So from my current point of view it's more like Sophos then Meraki. That's ok, I can work with that. I have other things preventing that kind of solution this side currently. But that's just a matter of time for me. I now have a direction to go in and a solid plan.
Cheers.
