sandinak
Mar 31, 2022Aspirant
WAX630 multiple SSID same VLAN?
So I am using this device in a mixed space, home and business. I have a bunck of Meross Homekit home automation type devices that all want to be on 2.4Ghz. And when configuring these .. the associat...
sandinak
Blunt nonsense, explained a hundred times at least before. There is NO technical reason for this. Complain to the maker of this IoJ to remove this idiotic restriction.
Agreed .. there shouldn't be. I can say with some confidence .. that when on the 5g with my iphone .. it's alot harder for the units to associate .. not even sure I can say it's actually worked specifically. But i can say it works on 2.4Ghz .. have to beat on the manufacturer for that one.
Perfect valid config, you can create multiple SSID with different security settings and also just select radio and assign these to the very same VLAN. Same on all WAC5xx, all WAX6xx, same on OpenWRT, same on Netgear Insight management. And I'm tempted to state also on the WAX21x.
Yup.. when using an L2 Bridge.
Curious: What do you designate as an AUTO SSID?
That's just the name i used.
schumaku
Apr 01, 2022Guru - Experienced User
The process for adding IoJ to a WiFi AP config is essentially
- Connect the Mobile to the SSID
- Copy the SSID (on Android also the Wireless key or ask for the PSK)
- Make mobile Search and access the typically hidden SSID for the IoT and push SSID and PSK to it, make the IoT restart
- Reconnect to the AP SSID
Note: At no point you need to choose 2.4 GHz 8-)
The only mistakes could be to apply some client isolation so the mobile can't discover the configured IoJ. Except of the special config allowing to assign a dedicated NATed network to an SSID - all plain L2 bridging.
