Brian86's avatar
Brian86
Tutor
Aug 08, 2022
WAX630 Wake on Lan
I recently upgraded the APs on my network using the WAX630 and I am now having a problem with Wake On Lan (WOL) messages reaching the Wi-Fi attached printer.  The printer works via Wi-Fi after it reboots - it will print documents from my computer.  However after the printer goes to sleep it can't be woken up by WOL requests - printing from the same computer that worked before no longer works.  This was not a problem before I changed the APs.
I found a reference on this forum stating that the WAX202 doesn't support WOL requests (https://community.netgear.com/t5/Business-Wireless/WAX202-Wake-on-Lan/td-p/2214925)
Does anyone know if the WAX630 supports WOL requests?
Thanks
Brian
  • Brian86
    Welcome to the Community!
    WAX630 does not support Wake On LAN (WoL).
    HTH
  • Marc_V's avatar
    Marc_V
    NETGEAR Employee Retired
    Brian86
    HTH
    • Brian86's avatar
      Brian86
      Tutor
      Marc_V , thanks for the information.
      Was there a way I could have known that ahead of time?  I don't see anything about it in the user manual.
      Brian
      • Marc_V's avatar
        Marc_V
        Brian86
        Have you checked the Product data sheet before buying? or the seller did not provide info? Since it is not supported it will not be available on the manual.
        HTH
ProSupport for Business
