Jap365's avatar
Jap365
WAX202 Wake on Lan
I have added the WAX202 access point to my network. But it looks like it blocks my WOL requests send by a connected wifi device. Do netgear access points support WOL package passthrough?
  • Jap365,
    I apologize for the late response. 😞
    I inquired your concern to the higher tier of NETGEAR Support and I got an update that Wake On LAN (WOL) is confirmed NOT supported on WAX202.
    DaneA
    NETGEAR Community Team
  • DaneA's avatar
    DaneA
    NETGEAR Employee Retired
    Jap365,
    Welcome to the community! 🙂
    Is your WAX202 set to Router mode or AP mode?
    What is the current firmware version of your WAX202?
    What is the specific wireless device/s that sends the WOL requests?
    Kindly post a diagram of your detailed network setup.
    DaneA
    • Jap365's avatar
      Jap365
      It is in AP mode with latest furmware 1.0.5.1.
      A raspberry pi (wireless connected to Wax202) sends a WOL command to a NAS (Wired connected to the WAX202). Wax 202 is wired to a Modem/Router. Without WAX is worked, wirh WAX it doesn't. Same IP's, same command.
      • DaneA's avatar
        DaneA
        Jap365,
        DaneA
ProSupport for Business
