Zzup's avatar
Zzup
WAX630E connecting 2.4 instead of 5 ghz
I just Bought 2 WAX630E to replace my Unifi AC wireless.  I am having issues setting them up right off the bat.  The main issue i see is there is no option to set a prefered band like on other system to push toward the higher frequencies.  I tried bandwidth steering and still nothing.  The main issue is that my devices are connecting at 2.4 ghz band instead of the 5 ghz band.  I switch them back to the unifi and they connect right to the 5 so i know it is not the devices.  And yes this is happening on 3 different systems.  Any ideas why this is happening?  I searched the setting and did full factory resets with no luck
  • I found that if you disable the 6 ghz portion of the AP then the clients correctly associate with the 5 ghz instead of the 2.4 ghz.  This seems to be a bug.
    Basically all i had to do to fix it was turn off the 6ghz on the SSID that i was using and the AX200 wireless cards all started connecting at full speed on the 5 ghz instead of 2.4.  Not sure why the 6 ghz would mater for a AX200 as they are not 6 ghz compatible but that is the solution.
    • schumaku's avatar
      schumaku
      With 6 GHz enabled WPA3 is mandatory, so previously configured clients for the same SSID and PSK might not work for other bands (without dropping the config and re-adding). Lack of insight, impossible to answer.
      • Zzup's avatar
        Zzup
        A fresh client with no config would do this behavior.  And when they connected to 2.4 they were connecting with WPA3.
        Also i should clerify that i did not turn off the 6 ghz radio but just disabled it on that one SSID.  Then i added a second SSID with just the 6 ghz.  With WPA 3 enabled on both.  This solved the issue for now.
ProSupport for Business
