GDrosario
Jan 17, 2024Aspirant
WAX630E not negotiating 802.3at POE+ via LLDP
Hello, I have a site that is transitioning to WiFi6 and the APs will need to be put on the existing Cisco WS-C2960X-48FPD-L switches as we are transitioning the access switches with a different p...
BrianL
Jan 18, 2024NETGEAR Moderator
Hi GDrosario,
Did you plug it in port 1 or the 802.3bt / 802.3at of the AP? Also, have you checked if there's enough power budget to supply the said AP? I have encountered problems before where WAX APs won't turn on CISCO POE+ switches, just have to enable and run "#lldp run" via CLI.
Take note that if the WAX630E is powered via POE+, the max throughput will be reduced to 50% on 5GHz.
Kind regards,,
