Halcyonon
Feb 02, 2024Tutor
WAX630E performance degrading
I've got a WAX630E that works great after a reboot, on 5 or 6ghz bands I am getting 500+Mbps (even through walls).. however after as little as a day (but the time can vary up to multiple days), the m...
BrianL
Feb 03, 2024NETGEAR Moderator
Hi Halcyonon,
I have responded to your reply on another thread that also has a speed issue with their WiFi. Kindly share if the unit is locally or Insight managed and if the speed also is degraded from the AP during speed check (speed test) when the issue occurs.
Management -> Diagnostics -> Speed Check
Kind regards,
