MagnetParlor
Nov 26, 2024Tutor
WAX630E Power Setting Isn't Honored After Reboot, Fix: Manually Cycle Settings Every Power Cycle
Info: Model WAX630E Firmware: V10.8.11.4 Bootloader: U-Boot 2016.01-V10.0.1.18 Power Source: PoE 802.3bt Managed by: Both local and Insight Potentially relevant settings: Multi-Link Operati...
- Nov 27, 2024
Thank for the details on recreation.
We will get back to you soon with either a work around or a patch image.
xjrguy
Nov 26, 2024Star
Make sure you have instant WiFi settings turned off in locations ->wifi (in insight)
There are two settings in there that might fix this if you disable them.
