andejo55's avatar
andejo55
Initiate
Mar 15, 2021
WBC502 5.8.4.3 Configuration in Progress for over an hour
Just tried applying firmware update 5.8.4.3 to WBC502 via Insight Cloud Portal and it's been sitting at Configuration in Progress for well over an hour.   Tried rebooting the device via Cloud Portal remotely but it didn't help.
  • schumaku's avatar
    schumaku
    Retry by cutting and reapplying the power. To bad these are not standard PoE[+[+]] devices so you could remote power reset at least the locally connected one.
    • andejo55's avatar
      andejo55
      Initiate
      I reapplied to firmware update but manually through the device directly.  This resolved the issue.
ProSupport for Business
