IssaquahHatch
Feb 27, 2022Follower
WBC502 to WBC502 Video Problem
I have two WBC502's with about 100m apart in a straight line. One is on my Xfinity network with 300 mb/s down and 35 mb/s up. At the remote end of the 502's I get two of the three strength bars, feedi...
Feb 28, 2022Guru - Experienced User
Is the speedtest running off the RAX10 or have you tested it directly into the WBC?
Do you have a straight line of sight between the WBC's? They should be able to handle more throughput at that close of range.
