JohnDonovan
Aug 18, 2020Aspirant
WC7520 'bricking" WNDAP360 - How to recover the AP ?
HI, I have an issue with my EoL WC7520 has 'bricked' a WDNAP360 that it tried to update the firmware on. There are a numer of threads on this already but they often state 'and i recovered the WD...
- Aug 20, 2020
Welcome to the community! :)
What is the current firmware version of the WC7520?
Not sure if this will help. I found this old thread here on how to recover the WNDAP360.
DaneA
NETGEAR Community Team
JohnDonovan
Aug 20, 2020Aspirant
Thanks, that is useful. Do I take it that what appears to be a second Ethernet port is the RS232 port?
The WC7520 is at the latest (last) firmware.
DaneA
Aug 23, 2020NETGEAR Employee Retired
The port next to the factory reset hole is the console port. Make sure that you set the following settings before you access the WNDAP360 via console: 9600 K default baud rate, (8) data bits, no (N) parity bit, and one (1) stop bit.
As reference, kindly check pages 12-13 of the WNDAP360 Reference Manual here.
DaneA
