Joost1992's avatar
Joost1992
WC7520 can't find the WNDAP360 in discovery Wizard
We have a WC7520 adapter with 5 working AP's, but i want to connect another AP to the WC7520.
When i updated the AP to the last firmware (these are fully factory reset), i still can't find them with the WC7520 in discovery wizard.
The adapter and AP are on the same network.
I tried all troubleshooting things, but still i can't find them.
sombody knows what to do?
Thanks...
  • Hi,
    Welcome to the netgear community!
    Can you login to the new AP UI and enable the SNMP, and try discovery again.
  • Hi,
    • Joost1992's avatar
      Joost1992
      Hi!
      Thankyou!
      I enabled SNMP and it works, i can find the AP now, but the next problem is dat the Status is still on '' AP rebooting ''
      And i don't see that AP rebooting, there is nothing going on..?
      Do i need to enable another thing? haha
      Joost
      Joost1992
      I tried this morning again to make connection with the WC7520 too WNDAP360.
      There is now a connection, i can see them and i add them to the dicovery list,
      But then they ask for firmware update and the AP will reboot but...
      Then it's stuck.. nothing is happening then. the AP is not rebooting.
      Firmware WC7520 = 2.5.0.45
      Firmware WNDAP360 = 3.7.9.0
      I installed allready 2 other AP's last week, but the others won't work...
ProSupport for Business
