ldonigan
Dec 16, 2016Aspirant
WC7520 Is latest firmware 2.5.0.39 or 2.5.0.42
Hello,
Hi laxman,
Is the latest firmware revision for the WC7520 wireless controller 2.5.0.39 or 2.5.0.42? Someone told me the latest revision is .42. Is that correct? I only see .39 on the web site.
Thanks
Lee
Hello ldonigan,
Welcome to the community!
As of now, the latest firmware version for the WC7520 is the 2.5.0.39. We always recommend the firmware versions on our download page. Do you have any link mentioning the firmware 2.5.0.42?
Thanks,
- JohnRoNETGEAR Employee Retired
Hello ldonigan,
Thanks,
Hi ldonigan,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
