SidS
Dec 15, 2016Follower
WC7520 w/ WNDAP360's - firmware update sequence
I'm getting ready to apply firmware updates to my WC7520/WNDAP360 wireless system. I've downloaded the 2.5.0.42 firmware for the controller, but its release notes say the firmware on the AP's must b...
- Dec 16, 2016
Hello SidS,
Welcome to the community!
There is no need for a rollback. When an APs are connected to a controller, its maintenance and upgrade are centralized and managed by the controller. It is using a special firmware (Thin Firmware) pushed by the controller. What you are looking at (FW 3.5.20.0) is a standalone firmware.
Thanks,
JohnRo
Dec 19, 2016NETGEAR Employee Retired
Hi SidS,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Thanks,
