JanHruska's avatar
Dec 12, 2016
WNAP320 upgrade sequence
I would like to upgrade a standalone WNAP320 2.1.1 to the current firmware. The upgrade sequence described in http://kb.netgear.com/31401/WNAP320-Firmware-Version-3-5-20-0?cid=wmt_netgear_organic is contradictory, gives two examples:
1. AP running 2.x, first upgrade to 2.1.6. Then upgrade to 3.5.20.0
2, Example firmware upgrade sequence for WNAP320 from 2.x:
V2.1.11 -> V2.1.12 -> V3.5.20.0 - Correct sequence
It also implies that 2,1,5 is the earliest version that can be upgraded for WNAP320 ("Upgrade initiated from other 2.x firmware version is not supported.").
What is the correct sequence?
  • Hi JanHruska,
    For your WNAP320 which is having the firmware version 2.1.1 please find the below correct squence.
    2.1.1 -> V2.1.6 -> V3.5.20.0
    Thanks
    Raghu
  • RaghuHR's avatar
    RaghuHR
    NETGEAR Expert
    Hi JanHruska,
    Thanks
    Raghu
ProSupport for Business
