AZstevep
Nov 27, 2021Follower
WC7600v2 QoS setting for UDP data only usage
I have an installation with WC7600v2 connected to 10 WND930 access points. This is a data only application with many small packets being transmitted per second. Typically there are 50 uplink messages (150 bytes each) per second and 50 downlink messages (50 bytes each). Is there an preferred QoS settings for this applicaition? In my debugging, I see data fragmenting when I look at the data using tcpdump. I'm new to QoS and it's not obvious how to optimize the QoS for my data only application.
No RepliesBe the first to reply
