BishopTinsly
Jul 01, 2016Aspirant
WC9500 not sending info to RADIUS server
I have a WC9500, set up for WPA2 with RADIUS, i have the correct profile and RADIUS sever set up, i can ping the WC from the RADIUS and vis versa. however when i go to auth to the RADIUS server nothi...
- Jul 26, 2016
It was a defective WC, a new one needed to be sent out to resolve.
DaneA
Jul 04, 2016NETGEAR Employee Retired
Hi BishopTinsly,
Kindly answer the questions below:
a. Was this working fine before?
b. What is the current firmware version of the WC9500?
DaneA
NETGEAR Community Team
BishopTinsly
Jul 05, 2016Aspirant
It has only been set up in the way that it is now, and the WC is running Firmware version: 5.5.1.0.
- BishopTinslyJul 05, 2016Aspirant
I updated the the WC to the latest frimware V5.5.1.4, did not resolve the issue
- DaneAJul 05, 2016NETGEAR Employee Retired
Hi BishopTinsly,
I think it would be best to open an online case with NETGEAR Support. Let them know about your concerns for further technical assistance.
DaneA
- JohnRoJul 08, 2016NETGEAR Employee Retired
Hi BishopTinsly,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
- thchengJul 08, 2016NETGEAR Expert
Hi,
Can you check to see if you have the right shared key for the Radius server set up? Have you received feedback from NETGEAR support on your issue yet?
Thanks,
Thomas
