BishopTinsly
Jul 01, 2016Aspirant
WC9500 not sending info to RADIUS server
I have a WC9500, set up for WPA2 with RADIUS, i have the correct profile and RADIUS sever set up, i can ping the WC from the RADIUS and vis versa. however when i go to auth to the RADIUS server nothi...
- Jul 26, 2016
It was a defective WC, a new one needed to be sent out to resolve.
thcheng
Jul 08, 2016NETGEAR Expert
Hi,
Have you had the chance to reference the user manual for WC9500? The document is retrieavable from the below link:
http://www.downloads.netgear.com/files/GDC/WC9500/WC9500_UM_3Jan2106.pdf?cid=wmt_netgear_organic
the setup for Radius page is reference on page 143.
Select Configuration > Security > Advanced > Authentication Server
Thanks,
Thomas
