Timmeke
Jun 22, 2022Aspirant
Wd930 issue
I have wd930 issue. After correct installation I connected my laptop with utp for configuration. After typing the correct IP address for wd930. I get the login screen. After entering admin as usern...
- Jun 22, 2022
Timmeke wrote:
After correct installation ...Possibly.
Access point is new from box and the unprotected wifi is working perfectly on the acces pointIn that case you can open a support case with Netgear. Support is free for the first 90 days after purchase.
Then again, the WN930, which, as FURRYe38 suggests, this may be, dates back five years or more.
Jun 22, 2022Guru - Experienced User
Is this a NG product? That model doesn't ring up...
Timmeke
Wnd 930 outdoor dual band access point
- FURRYe38Jun 22, 2022Guru - Experienced User
- michaelkenwardJun 22, 2022Guru - Experienced User
FURRYe38 wrote:
I see:
https://www.netgear.com/business/wifi/access-points/wnd930/
Crikey. Good bit of research there.
An old bit of Netgear stuff from a long abandoned range.
Usual boilerplate replies.
Manuals are always a good place to start.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Business Wireless - NETGEAR Communities
