Timmeke
Jun 22, 2022Aspirant
Wd930 issue
I have wd930 issue. After correct installation I connected my laptop with utp for configuration. After typing the correct IP address for wd930. I get the login screen. After entering admin as usern...
- Jun 22, 2022
Timmeke wrote:
After correct installation ...Possibly.
Access point is new from box and the unprotected wifi is working perfectly on the acces pointIn that case you can open a support case with Netgear. Support is free for the first 90 days after purchase.
Then again, the WN930, which, as FURRYe38 suggests, this may be, dates back five years or more.
michaelkenward
Jun 22, 2022Guru - Experienced User
Possibly.
