Alexdbv
Feb 09, 2017Follower
WFS709tp ssh enable password?
Hi! Prompt the password for "enable" at an entrance on ssh on the controller.
- Feb 17, 2017
Hello Alexdbv,
Welcome to the community!
I just like to inform you that the enable password is reserved for engineering/support use only. It is also not possible to set enable password on the GUI or using the console, this is normally the case when the enable function is reserved for engineering use only. This is not for end-user usage.
Thanks,
JohnRo
Feb 17, 2017NETGEAR Employee Retired
Hello Alexdbv,
Thanks,
- JohnRoFeb 20, 2017NETGEAR Employee Retired
Hi Alexdbv,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
