Good8WiFi
Mar 29, 2021Follower
Will WAX214/218 become Insight manageable?
Questions:
WIll WAX214 and WAX218 become netgear Insight manageable?
and btw, the WAX214 and WAX218 isn't in the model list. Will it be added?
Thanks.
Good8WiFi wrote:WIll WAX214 and WAX218 become netgear Insight manageable?
Very unlikely, different product class.
Good8WiFi wrote:and btw, the WAX214 and WAX218 isn't in the model list. Will it be added?
ChristineT please, many newer SBU SKUs are missing here in the tags 8-)
- gramosAspirant
Hi Good8WiFi
WAX214/218 will not have an Insight manageable because they are a different product line. This product is part of the essentials product line. If you would like to modify any feature of your AP you can enter its IP address in the search tab of browser and log in to its user interface.
- douglas_cheungNETGEAR Expert
A comparable product to WAX214 and WAX218 would be WAX610 and WAX620, respectively. The WAX600s are all Insight managed.
WAX615 is a good choice too. it is dual band, 2x2 each band. Power is as low as WAX610. Throughput is almost twice as fast because of the 160MHz channelization technology (so called WiFi 6 Release 2).
Doug
