akwin
Jan 05, 2017Aspirant
Wireless router recommendation for small business
Hi, I am setting up a server, five workstations, and two wi-fi connected laptops in a small business. What switch/wi-fi router combo would you recommend? I also want the ability to set up a guest...
- Jan 10, 2017
Hi Alan,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
JohnRo
Jan 06, 2017NETGEAR Employee Retired
Hello akwin,
Welcome to the community!
A Nighthawk router along with a gigabit switch should do the job, it can definitely fill the needs of your small network. It also has a guest network setting and very easy to setup. If you think that the network will be bigger, you may also consider getting a ProSafe Firewall and Access Point. They are more secure and has features like VPN that you can use to manage your network remotely.
Thanks,
