akwin's avatar
akwin
Wireless router recommendation for small business
Hi,   I am setting up a server, five workstations, and two wi-fi connected laptops in a small business. What switch/wi-fi router combo would you recommend? I also want the ability to set up a guest...
  • JohnRo's avatar
    JohnRo
    Jan 10, 2017
    Hi Alan,
    We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
    If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!
    Thanks,
ProSupport for Business
