akwin
Jan 05, 2017Aspirant
Wireless router recommendation for small business
Hi, I am setting up a server, five workstations, and two wi-fi connected laptops in a small business. What switch/wi-fi router combo would you recommend? I also want the ability to set up a guest...
- Jan 10, 2017
Hi Alan,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance.
If your issue is now resolved we encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The Netgear community looks forward to hearing from you and being a helpful resource in the future!Thanks,
akwin
Jan 06, 2017Aspirant
John,
Thanks for the reply.
Should I choose unmanaged or managed switch?
How would I connect the switches and router? I assume I would connect the switch to modem and connect Nighthawk to gigabit switch.
Alan
JohnRo
Jan 06, 2017NETGEAR Employee Retired
Hi Alan,
If you plan to have VLANs in the future, I would suggest a manageable or smart switch (But be aware that the router also needs to support VLAN for routing purposes). The setup will be, Modem>Router/Firewall>Switch(es)>Clients.
Thanks,
