RTC2
Feb 28, 2025Follower
Wireless setup for small business - outbound access only, no on-prem resources
We are a small non-profit and have decommissioned all on-prem servers, databases, and applications and moved them to Microsoft Azure cloud and MS365 E5 (Entra, Defender, Intune, Office apps, etc.) ab...
Feb 28, 2025Guru - Experienced User
I was a huge fan of the Orbi pro's for this kind of thing for simplicity and easy of use. But they've been EOL'd. If you're not needing massive amounts of users/coverage/speeds, a used orbi pro system can be picked up cheap but you'll not have much for support. Otherwise, business class wise, you'd be looking at the insight series
