_Richman
Mar 30, 2016Aspirant
(GS108Tv2) VLAN Sharing Resources
I am looking at replacing the unmanaged switch in the diagram above with a smart managed switch to help separate the network into two. Not shown (and not fully implemented) will be a second network which is mainly focused around IP cameras of which I want to connect to the NAS. I was recommended that a VLAN enabled switch could help me in this problem, but I am quite limited on my knowledge on if this is even possible.
The network I'm trying to create should be that the IP camera network and home network should not be able to talk to each other but can still share and access the NAS as needed. Is the GS108Tv2 capable of this, plus how would one go about configuring a managed switch in this way?
Hello _Richman,
Please read this article (click here), this will give you an idea and explanation on how and when VLANs are used. It includes and example on how to setup a VLAN properly based on the setup that you want to achieve.
Let us know if you have questions.
Thanks,
- DaneANETGEAR Employee Retired
Hi _Richman,
Welcome to the community! :)
What is the brand and model of your NAS? For me, I think you will need to configure Asymmetric VLAN for you to achieve your goal. Kindly access this article as reference guide. Hope it helps :)
DaneA
NETGEAR Community Team- _RichmanAspirant
Thanks for the quick reply.
It's a Synology DS216+.
I should have also mentioned that I am completely new to what managed switches can do, including VLAN's.
- JohnRoNETGEAR Employee Retired
Hello _Richman,
Thanks,
