_Richman
Mar 30, 2016Aspirant
(GS108Tv2) VLAN Sharing Resources
I am looking at replacing the unmanaged switch in the diagram above with a smart managed switch to help separate the network into two. Not shown (and not fully implemented) will be a second netwo...
_Richman
Thanks for the quick reply.
It's a Synology DS216+.
I should have also mentioned that I am completely new to what managed switches can do, including VLAN's.
JohnRo
Mar 31, 2016NETGEAR Employee Retired
Hello _Richman,
Please read this article (click here), this will give you an idea and explanation on how and when VLANs are used. It includes and example on how to setup a VLAN properly based on the setup that you want to achieve.
Let us know if you have questions.
Thanks,
