djqkat
Mar 21, 2017Aspirant
WNAP210 v2 - Connection getting slower during 24hrs
Hi there, I have a WNAP210 v2 which is connected to a Hitron CVE-30360 I got from my ISP (so I have to use it). The Hitron functions as a DHCP server, the DHCP function of the WNAP210 is turned ...
DaneA
Mar 29, 2017NETGEAR Employee Retired
Thanks for the update. I'm glad to know that changing the wireless channel and switching off AMPDU helped resolve the problem.
Feel free to post your future concerns here in the community! :)
DaneA
NETGEAR Community Team
djqkat
Apr 06, 2017Aspirant
Hi DaneA,
after some days it looks like it is still not working like expected.
The connection is getting slower over time, until it is not possible to use WiFi any more.
My temporary solution is a time switch to cut power during the night and so force the access point to reboot. After this the connection is fast again.
It feels like there is a buffer which is getting full or a log-file which is getting too big?!
Do you have an ideas?
Greetings,
Robert
- DaneAApr 06, 2017NETGEAR Employee Retired
I have just re-read this thread. Kindly try to perform a factory reset on the WNAP210v2 then reconfigure it from scratch. Observe if the same problem occurs.
If ever the same problem recur, I suggest you to open an online case with NETGEAR Support for further assistance. Kindly state your concern and the troubleshooting steps you've done so far to isolate the problem.
DaneA
- Jan 17, 2024Retired_Member
