xeonnet
Oct 08, 2017Initiate
WNDAP360 fw 3.7.7.0 issues
I have a WMS5316 (fw 2.1.5) AP controller and seven WNDAP360 AP's (fw 3.6.9.0). I now updated three of the AP's to the latest fw version 3.7.7.0 (also via fw version 3.7.4.0). But I have not been ab...
- Dec 11, 2017Hi I'm testing the new (!) fw beta version for the WMS5316, Beta version 2.1(A).6, and it works just fine with the lastest fw for AP's WNDAP350 and WNDAP360 (now running on the latest fw ver 3.7.9.0). No issues! I've been told that the new beta fw 2.1(A).6 will be released in 18Q1. So the great WMS5316 is not EOS or EOL...! Regards XeonNet
DaneA
Oct 18, 2017NETGEAR Employee Retired
Welcome to the community! :)
Thanks for the comment. It is possible that the links about where to buy the WMS5316 was not removed after it was declared EOL (End-of-Life). Also, the NETGEAR EOL (End-of-Life) webpage is still being worked on as of now to include all of the NETGEAR devices that were discontinued.
DaneA
NETGEAR Community Team
- kiptanOct 18, 2017Aspirant
Thank you. Can you tell me if the WC7500 is compatible with the latest 3.7.7.0 update please?
We'd prefer to not have to spend more then £900 on equipment just so we can manage APs with the 3.7.7.0 update on.
Regards
- DaneAOct 18, 2017NETGEAR Employee Retired
The WC7500 is compatible with the WNDAP360 using firmware v3.7.7. The latest firmware version for the WC7500 is v6.5.3.1. Kindly check the release notes here which includes the minimum standalone AP firmware version required to be discovered by the WC7500.
DaneA
- RonnyAdsettsOct 20, 2017Tutor
Hi,
Just found this thread after upgrading all our WNDAP360's to 3.7.7.0. To say I'm bloody annoyed is an understatement. The release notes would have been a good place to point out that the upgrade (that mentions 1 fix only for the KRACK WPA2 issue) would break connectivity with the controller!
So we now have hardware that's still listed on the Netgear website as compatible that really is not.
Will Netgear produce a 3.7.7.1 fix to reinstate compatibility? I'd hope so if only to restore some level of confidence.
Thanks.
Ronny
