JATINDPCS
Jul 05, 2018Aspirant
WNDAP360 RMA / Replacement
Our AP is faulty and Unable to Browse the AP, Power LED continuously blinking Amber and cannot find the SSID broadcasted by AP. Reset several times but no effect. result is same. Also Status & LAN LE...
- Feb 04, 2019
Hi JATINDPCS,
I checked the progress of your case # 40041995 and I got an information that you have already received your refund on your bank account. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Jul 05, 2018NETGEAR Employee Retired
Hi JATINDPCS,
Welcome to the community! :)
I have already forwarded your concern to the NETGEAR Support Team. A NETGEAR Support Expert will be assigned to your case # 40081701 and will respond to it.
DaneA
- JATINDPCSNov 22, 2018Aspirant
Dear Dane,
With reference to my subject mentioned RMA / Replacement for WNDAP360, i already got a call back from Mr. John (Netgear L1 / L2 Engineer) who assisted us on the Access Point and then finally concluded that the AP is faulty and needs to be replaced. SInce replacement was not possible as the model is discontinued, he processed a RMA with a refund of Money for an amount of USD 175/- already couple of months ago and informed me that the another person from Finance dept. will take over the ticket and send us the money in the Bank account which was already shared to John.
Nothing has been rolled on after that and we sent multiple reminders on the ticket update but there is no initiative from Netgear team in order to help us resolve this issue.
We never anticipated such a support from Netgear or any vendor in my life. Its a disgusting support where we are struggling for the past 6 months to get our problem resolved.
Our Ticket History – Case #40041995
Await quick feedback from the respective team and help us resolve this issue.
Jatin
+971-56-4173108 & +971-52-8836303
Dubai - UAE
