Warranty & Contracts
3 TopicsPerformance Degradation:
We are experiencing significant performance degradation with our Netgear wireless network. The speed tests are consistently lower than expected, and large file transfers are painfully slow. Are there any recommended configurations or firmware updates to improve performance?"1.1KViews0likes1CommentWNDAP360 RMA / Replacement
Our AP is faulty and Unable to Browse the AP, Power LED continuously blinking Amber and cannot find the SSID broadcasted by AP. Reset several times but no effect. result is same. Also Status & LAN LED are Steady Green. We raised a complaint with Netgear Online and got a CASE ID # 40081701 dated 19-JUNE 2018 but until so far there is no response from Netgear team. can anybody advise how can i reach the RMA Support?Solved4.3KViews0likes6CommentsWC7520 not sending Authentication to Radius
We have 3 Wireless controllers WC7520 and more than 30 AP's (all WNDAP360) in our environment. We configure Radius server on a server running Windows Server 2012r2 with NPS. We using WPA2 with AES encryption, we have the correct profile and RADIUS server set up however when we go to authenticate in the RADIUS server nothing happens. The worst part is there is no log incident created on the RADIUS server. The firmware of our Wireless Controller is: 2.3.1.5_3034. Any Advice? thank youSolved6.1KViews0likes7Comments
