JATINDPCS
Jul 05, 2018Aspirant
WNDAP360 RMA / Replacement
Our AP is faulty and Unable to Browse the AP, Power LED continuously blinking Amber and cannot find the SSID broadcasted by AP. Reset several times but no effect. result is same. Also Status & LAN LE...
- Feb 04, 2019
Hi JATINDPCS,
I checked the progress of your case # 40041995 and I got an information that you have already received your refund on your bank account. :)
Since your concern has been resolved, I encourage you to mark the appropriate reply as the “Accepted Solution” so others can be confident in benefiting from the solution. The NETGEAR Community looks forward to hearing from you and being a helpful resource in the future!
Regards,DaneA
NETGEAR Community Team
DaneA
Nov 22, 2018NETGEAR Employee Retired
Hi JATINDPCS,
I inquired your case # 40041995 to the NETGEAR Support Team and found out that John is not assigned to it anymore. Your case # 40041995 is currently handled by the Customer Care Team.
I already sent a follow-up e-mail with regard to your concern to the appropriate NETGEAR authorities to work on your refund. I will post here once I got a feedback.
DaneA
JATINDPCS
Nov 22, 2018Aspirant
Dear Dane,
Many thanks for your prompt response and hope i get someone responsibile enough from Netgear to help me on refund at the earliest.
Jatin
